Hi guys, Im hoping desperatly someone can help me here. So it all started when I plugged my phone into my laptop, it crashed and then came up with:
Bootloader 03.0A
Code Corrupt
Ok to Program
Battery Ok
Connect USB
So I flashed it using: Droidpro_2.26.20.sbf and RSD lite 4.9/5.1.
Now it gets past bootloader but goes straight to a boot loop, I then tried to stock recover it. When I got there it read:
Android syste recovery <3e>
Reboot System now
apply sdcard:Update.zip
wipe data/factory reset
wipe cache partition
E: Can't open /cache/recover/command
E: Can't open /cache/recovery/caller
None of the opitions work.
I cant find any fixes anywhere, did I use the wrong SBF? Is there anyway to fix this? Any help would be greatly appericated.
Bootloader 03.0A
Code Corrupt
Ok to Program
Battery Ok
Connect USB
Reboot System now
