That's the really tough one. There are a fair number of compliant 6 ft. A to C cables, and a few compliant 3.3 ft. C to C cables, but for some reason compliant 6 ft. C to C is a unicorn. I just bought
the dual port charger from the Google Store, in part because it comes with a separate 6' cable (in black no less!). I'm going to use it with the stock charging block in one location where I need the length, and use the dual port charger and two Benson-approved 3.3 foot cables (for both my XL and my C tablet) in another location. The only other 6 ft. C to C cable that looked like a possible choice was [URL="https://www.amazon.com/Cable-WiRoTech-Orange-USB-C-Charging/dp/B01E1O1R02/?tag=hawk-future-20&ascsubtag=UUacUvbUpU5567595]this one[/URL] on Amazon, but there's no sure indication that it's compliant.
It's hardly a unicorn, they're tougher to find but there's at least half a dozen well vetted 6ft Type C cables out there. This list linked below isn't linked enough, it focuses a bit more on 3.0/3.1/TB cables (which tend to be pricier) BUT it has several 6ft USB 2.0 recommendations (along with some faster ones and even an 8ft I'm almost tempted by).
https://docs.google.com/spreadsheets/d/1vnpEXfo2HCGADdd9G2x9dMDWqENiY2kgBJUu29f_TX8/pubhtml
It's curated by Nathan K who has collaborated with Benson, unlike the other often linked sheet which is often attributed to Benson but not actually curated by him, and from what I've seen a little less well maintained... No discredit to the author tho, they just have a slightly different focus.
In any case, assuming you want to avoid paying $30+ for your 6ft cable and you only need it for USB PD fast charging, the two best options are actually the OEM ones. Apple's is currently $20 thru the end of the year (donglegate sale, no kidding), and is probably the best overall based on actual evaluations:
USB-C Charge Cable (2 m) - Apple
I'm about to purchase one myself... If you don't wanna give your money to Apple for whatever reason, or you prefer a more rubbery grey shade of white, Google's cable is $25 but it might not suffice for charging a big MBP (more than enough for phones and even the standard MB or smaller MBP tho):
https://forums.androidcentral.com/e...usb_type_c_usb_type_c?hl=en-US&token=UVT2oZ1e
It's a slightly updated version of the black one you're getting with your Google dual charger but both are fine IIRC, I like the strain relief on Google's better than Apple's but that's somewhat subjective and would require long term use to bear out any true significance.
The only thing I'd say about Google's somewhat overpriced cables is that, as you alluded to, they made a lot more sense when bought with a charger. At $25 even Apple's is cheaper (thru Dec at least), but at $35 with a spare 18W charger is nearly a bargain given the messy messy state of aftermarket cables:
https://forums.androidcentral.com/e.../store.google.com/us/?hl=en-US&token=rFi2TeOG
Or at $40 with the dual charger as you said.
