[Guide] Malware / Adware / Popup Removal
Status
Not open for further replies.
AlphaTango414
3,939
95
If you find yourself plagued with annoying pop-up ads, here are several steps to take in getting rid of these annoying pests.
"Why am I getting these for?" you may ask. Your phone has been infested with adware. The most common way of getting adware is by downloading \ installing non trusted apps/files to your device that has the adware hidden in them.
First, let's boot into safe mode. This will deactivate all third-party apps installed on your device. If the pop up(s) have stopped you know a third-party app is the source. If you can find the responsible app you will not have to reset your device.
Now start by making a list of all recent downloads you made. Starting with the most recent, uninstall apps one by one until the pop ups stop. Note which one took away the pop ups. That way you can avoid it in the future and if possible report the app/download as spam/adware.
Wipe system cache via recovery afterwards.
Secondly, if you have uninstalled all user apps and you still get pop ups, it's time to wipe all app cache. (Setting>System>Storage) Turn device off, boot into recovery and wipe system cache.
Finally, if neither of the above worked, you will need to preform a factory data reset. Before you do so, backup only the most important things you need. Go to settings>back up and reset>Uncheck automatic restore.
Preform the FDR. Upon setting your device back up, make sure not to restore via your Google account. Select set up as New Device.
NOTE: Restoring your device via Google backup can infact restore the very files that are causing you problems.
Root users, you may need to reflash back to stock. Since root permission allows system files to be altered, a simple FDR may not get rid of the adware.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,370
118
63
Another suggestion is to boot into safe mode if it can. That can eliminate if it is a 3rd party app.
Good write up
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,406
267
83
Here's something I encountered recently, on an iPhone.
Yes, of course I'll tell you my account details and password.
Tim1954
Q&A Team
Jan 17, 2016
6,924
Crikey! Might as well just give them your passport and banking details... the scary thing is that a lot of ppl actually do complete those!!!
xero1846
While this information is good, when you get the app that caused it, if the problem persists (as was the case for me only when clicking links within the facebook app) need to go into your facebook profile on a computer, click on your home page, then on the left side go down to apps and click "more" you'll see the whole list of legitimate apps that have access to your profile, and in my case, a few suspect ones with very generic and vague names, remove them. The problem has gone away for me so far. Good luck.
tarrystone
Thanks for pointing me in the right direction, but . . . . . . Does everyone know how to boot their device in 'Safe Mode'? I certainly don't :eek:)
Regards
Tarrystone
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,673
4,823
113
Welcome to Android Central! On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
However, certain phones have a different procedure, like Samsung. You can typically search for the correct procedure on the web by Googling "[your phone] Safe Mode."
recDNA
8,694
112
63
OK now in safe mode exactly what do you do?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,673
4,823
113
Safe Mode will disable any app that wasn't preinstalled, so if the offending app is causing problems, this should temporarily stop the issue. You can then start uninstalling apps one by one, to narrow down which app is the culprit. It can be a tedious process, but unless you have some clue as to which app is causing the problem, this is probably the only way to do it.
reinbeau
230
Here's the thing. The ONLY website I get this message from is https://truepundit.com/ . Be careful if you follow that link while mobile. And it only happens every two or three visits. The shriek is piercing, and this is the message I get:
The only way out is by turning off the phone. It does not appear again until I go there again.
I am extremely careful about programs I download. I don't download games or fluffy stuff, only useful, and all of the programs I have on my Note I'm very familiar with. So what I want to know is why is this Applock app, which seems legitimate, on the Play Store, allowing themselves to be associated with this kind of crap?
Status
JT1981
