gshockxcc
Hi, new to the forum, and trying to root, but it won't generate the bug report when holding the Volume Up and Power. Tried several times. I have verified the version, 4.1.2., XT907, and USB debugging is on. Also, tried replacing su and Superuser files.
Thanks,
Udate: Found this You Tube video that worked. Could be the key is to also "allow mock locations" and "unknown sources." I had to search for it, but "unknown sources" is located in Settings >> Security
Hope this helps anyone else who might need it.
Thanks,
