How do i move my ringtones saved in 'storage/audio' folder to ringtones folder on turbo?
A
AC Question
salesperson moved my purchased ringtones from rzrm phone to turbo when I purchased new phone last week.. but the files are in storage>audio folder and there is no menu to copy or move etc .. how do I get them into the turbo ringtone folder so I can use them?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,642
4,786
113
Welcome to Android Central! Are you unable to copy them using the file manager app? You could use a 3rd party file manager like Total Commander or X-Plore. Or you could connect to your computer via USB and use Windows Explorer to copy the file.
What's the exact directory name? If you're looking at a system directory, you can't manipulate files there if you're unrooted--but I would guess the salesperson wouldn't have been able to put it there in the first place.
joeyblack
