How do I root a Samsung Galaxy s5, and do I need a usb data transfer cable?
birb xd
I want to root my Samsung galaxy s5, but I'm wondering if I need a usb data transfer cable. Also, how do I root it? I know I need a computer, which I have. My model number is SM-G900F, Baseband version G900FXXU1CPFG, android version 6.0.1
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,590
6,174
113
Why do you want to root it? Yes a cable and computer you need , download Odin flash tool
And check XDA forum for advice .
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
I moved this from the Marshmallow forum to the S5 Rooting/ROMs forum for more specific traffic.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
The F should have an unlockable bootloader, so Magisk should be installable. See Magisk General Support / Discussion for more information about it.
And yes, you need a PC or laptop and a cable.
But, as mustang asked, why do you want to root it? You aren't running any apps that require root access now, so unless there's an app that you want to run that requires root access, rooting the phone won't change anything. (Rooting doesn't change the way any app works, unless the app requires root access, in which case it won't work without root.)
sdaservices2000
