Theot
as long as you flash the CWM file yes it just gives you clockwork
Got it, thank you sir! Posting this from my new rom/kernel combo!
can the same thing be done on the g2 because i've been having problems tryin 2 do it i cnt get into cwm all i keep gettin is this red triangle whenever i try 2 go aboot in recovery r something that red triangle pops up so if u can please help me
same error
ok so what method did you use to apply clockwork...
i used odin and the CWMRecovery_DJ05_DL09.tar.md5 file.
followed post 2 section 2.
had to boot directly into CWM to get the backup to work, but still gives me the same errors when i try to use rom manager to install new roms.
any clue where rom manager downloads to?
i cannot access my sd card from pc anymore for some reason.
