mstulanovic
1. Make sure you have the Android SDK installed. Read HERE for more info.
2. Download 4shared.com - online file sharing and storage - download flash_image.zip
3. Download 4shared.com - online file sharing and storage - download recovery-RA-heroc-v1.5.2.img
4. Unzip the first file, and place both in your Android SDK/tools folder.
5. Make sure USB debugging is ON
6. Connect your phone to the PC
7. Open the command window and navigate to the Android-sdk/tools folder on your computer.
8. At the prompt enter the following, one line at a time followed by enter
9. Your phone will reboot. When it is finished, back at your command window, once again enterCode:adb shell su mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system exit exit adb push flash_image /system/bin adb push recovery-RA-heroc-v1.5.2.img /sdcard adb shell chmod 0755 /system/bin/flash_image reboot
Code:adb shell su cd /sdcard flash_image recovery recovery-RA-heroc-v1.5.2.img reboot recovery
10. With any luck, you'll have the recovery image back and can load custom 2.1 based ROMS again.
Hello there
I have a small problem... i had cm-hero-recovery.img... and wanted to flash the new recovery-RA-hero-v1.6.2.img...
I did everything normally like I did with the first recovery img... but now I couldn't access the recovery (black and green screen). I tried boot via fastboot boot recovery-RA-hero-v1.6.2.img but only I get is this:
hamo@hamo:~/sdk/tools$ sudo ./fastboot boot recovery-RA-hero-v1.6.2.img
downloading 'boot.img'... FAILED (remote: not allow)
than I tried to flash the image with Flashrec the only thing I get is 'Failure'... no hope for me...
after that I was surfing the net and sow your post here... and than I did exactly what u said in the first post... and every thing went fine... and smooth.. with no errors... but when got to the adb reboot recovery command it did restart my phone... but it stuck on Hero screen... and nothing... I had to take out the battery and that turn it again... and couldn't access the recovery again...
what should I do?
Thanks in advance...
Hamo
