jon1371usmc
Quote: 7. "If I don't want to use softkeys, can I remap the hardware buttons to do something different?
Yes. In Root Explorer, navigate to system/usr/keylayout, make a backup of TWL4030_Keypad.kl, then open the original with text editor and change the entry for key 115 ( volume up) and/or key 114 (volume down) with something like BACK, MENU, or SEARCH. Save the file. Reboot, and they'll be whatever you changed the entry to.
If you want easy volume controls after remapping these buttons, a market app called Volumer++ can be set to live in your notifications for easy access. Otherwise, you can change them from settings."
Can anyone tell me how to do what is highlighted in red. Or what about adding volumer++ to the quick settings? Thanks.
