I had been rooted using the unrevoked method, but haven't been using a custom ROM, just rooted. ClockworkMod Recovery came up, had to select the update.zip. It installed, then rebooted. Sat on the Droid eye for a long time, then showed the unlock screen, but with no network service. I unlocked the phone and it showed a white screen with HTC logo and began installing process from 0-100%. near the beginning I keep getting a notification that "Sorry: Process system is not responding." with the option to force close or wait, whichever I pick, the install just keeps going in the background, then it reboots when it hits 100%, shows the droid eye, unlock screen, etc... and repeats the same process over and over and over again!
Battery pull got me into the main screen, but still getting the Process system not responding message. I then tried doing a data wipe/factory reset within ClockworkMod Recovery, but it finished immediately. I think it's wiping data from the Froyo version, which there isn't any yet.
I'm not sure if it's the ClockworkMod Recovery that's breaking everything... is there any way to get rid of that and go back to the standard Android recovery menus?
Help!
Help!
