A
AC Question
I'm using 2115mAh battery on Moto e3 power which is GK40, but it comes with GK50 3500mAh, it's working fine and good backup. but the problem is it doesn't show accurate battery percentage, whenever I'm charging it show less percentage than it should be, when I restart the phone or remove battery and turn it on it shows real battery percentage..it means mobile thinks that I'm feeding 3500mAh battery .
The main problem comes when I unplug and use mobile, when it is near to 50 40% it suddenly drops to 0% and turns of showing "Shutting down" then gone...So my question is, is there any way to calibrate the mobile with this battery? or anything else to solve this issue, rather than buying GK50 for it...I can't buy cz its not available here, any help would be greatly appreciated
