[Index] Froyo EB13 ROM's, Kernels, Themes, & Other Mods [Updated 3/22]
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
FAQ
ROM's:
Q: What is a ROM?
A: The ROM or OS is the image of the operating system. Example, Honeycomb, Gingerbread, Froyo, Eclair, Donut and Cupcake these are considered the ROM. The term ROM(s) is usually used in the rooting and hacking community when referring to a modified or custom version of the original ROM/OS.
Kernels:
Q: What is a kernel?
A: In simple terms, a kernel is the main link to the ROM (OS) and tells it what to do and how to do it. Aside from stock kernels, modified kernels are used for overclocking the speed of processor and controlling of voltage usage, resulting in better battery life and other settings.
Themes:
Q: What is a theme?
A: A theme is a makeover of the ROM's UI (user interface) by means of changing backgrounds, text colors, icons, overall appearance. This could also include battery display mods, and other neat additions.
Other Mods:
Q: What is other mods?
A: This could be modified stock ROM applications, startup & shutdown boot animations and application restores/reverts & other misc. changes that can be flashed or installed.
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
ROMs
OS Compatibility: Froyo EB13
General Notes:To download a ROM just click on the "Location" link and it will take you directly to the ROM developers page.
Rom Name: [STOCK] EB13 - Deodexed Update from DI18 | Pre-rooted | *** ADDED VOICE DIAL FIX ***
Developer: Dameon87
Rom Name: MiUi Rom 1.1.21 [Feb 23rd] [Ext4] [v1] [sms FIX] [OC kernel]
Developer: Ahmgsk
Rom Name: CyanogenMod 6.2 for Epic BETA 1 [Support IRC]
Developer: noobnl, CMSGSTeam, skeeterslint, forcystos
Rom Name: Simply AOSP 2.1 [EB13 FROYO][AOSP-CLONE][Updated 2-23-11]
Developer: TheDub
Rom Name: midNIGHT ROM v4.0 (BYOR Edition) CW3/EXT4 Official Froyo EB13
Developer: ptfdmedic
Rom Name: [Stock Flash][Odin]EB13 Extended CW2.5+RFS or CW3+ext4 2/24/2011 inc. Root+Redir
Developer: art3mis-nyc
Rom Name: Ti-X Epic Rom v1.0 FROYO 2.2.1 !!OUT!! 2.23.11
Developer: dc13
Rom Name: ACE ROM
Developer: Paul627g
Rom Name: SUPERNOVA ROM - EB13/RFS/EXT4/CWM3 25Feb
Developer: a454nova
Rom Name: SyndicateROM Frozen 1.0.2 (Malanga) :: nCIQ/Voodoo Sound/no wipe :: 3/18
Developer: ACS Team
Rom Name: Bonsai4All EB13 V3.0.1
Developer: Mammon88 & Randy_T
Rom Name: AhmgskMod TrulyEpic v3 [Feb 26th] [RFS] [EXT4] [Cam Fix]
Developer: Ahgmsk
Rom Name: CyanogenMod 7 | ALPHA 1
Developer: Dameon87
Rom Name: VIPERrom [SynErgY] EXT4-RFS Dual EB13 5.0[OC/UV/VooDoo Sound/NO CIQ]
Developer: tphillips
Rom Name: Baked Snack 2.1 "More Undisputed ;)"
Developer: Hero_Over
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Kernels
General Notes: All detailed information can be obtained from the "Flashing" link from the developer if its not provided here in the list.
Kernel Name: Genocide 1.2GhzOC EB13 Kernel v0.4a Voodoo Sound!!!
Developer: Rodderik/Team Viper
Summary: See developers page for full change log
Pre-requisites: Rooted & ClockWorkMod installed
Tools Required: SetCPU or OverClockWidget
Flashing: xda developers
Kernel Name:Stock EB13 Dual Filesystem [EXT4/RFS] Kernel!
Developer: Dameon87
Summary: This is a PROPER release of the kernel, as it includes the new initramfs changes from EB13.
Pre-requisites:Rooted/CWM Installed
Tools Required:
Flashing: Stock EB13 Dual Filesystem [EXT4/RFS] Kernel!
Kernel Name: Kernel - EB13 camera video lag & sports mode FC fix
Developer: mkasick
Summary: Does what it says in title, otherwise a stock EB13 kernel
Pre-requisites:
Tools Required:
Kernel Name: Twilight Zone Kernel v1.0.3 - Hisako
Developer: tanimn/ACS
Summary: See change log at developers thread.
Kernel Name: Spartacus_v1.0_EB13_A2SD_1.3GHz With Battery Tweak
Developer: BThomas22x
Summary: See change log at developers thread. Too much to list here...
Pre-requisites:
Tools Required:
Flashing: http://forum.xda-developers.com/showthread.php?t=976197xda developers
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Themes
General Notes:
Theme Name:Emotionless Beast
Designer: MysteryEmotionz
Summary:
Pre-requisites:
Tools Required:
Theme Name:Froyo Crystalline EB13/CWM3 Live WP/ADW Theme|ZipAligned/PNG Optimized
Designer: dreamsforgotten
Summary:
Pre-requisites: Flash on deodexed verson only
Tools Required:
Theme Name: Honeycomb Fusion 1.1
Designer: amosher13
Summary:
Pre-requisites: Version 1.1 is fully no-CIQ (ie: SRF 1.0.1 / Bonsai 3.0.1 compliant) but should also work on EB13 ROMs without CIQ removed!
Tools Required:
Theme Name: Emotionless Beast[SFR]
Summary:
Pre-requisites: Running ACS Syndicate ROM
Tools Required:
Theme Name: Red Star ACS 1.0.1 MadHouse(Full&Standard),Bonsai 3.1
Designer: jstine671
Summary: Verified working for Syndicate 1.0.1 and Bonsai 3.0.1 ROMs
Pre-requisites:
Tools Required:
Theme Name : Black Alien Void for Syndicate and Bonsai Roms
Designer: jstine671
Pre-requisites:
Tools Required:
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Other Mods
General Notes:
Other Mod Name: Car Dock Fix for Froyo EB13
Designer: ???
Summary: Newer version of Samsung's "Car Home" app called Car Cradle, adds a music player icon and supports audio out threw USB
Pre-requisites: Rooted running EXT4/CWM3.0.0.6
Tools Required: Flash in CWM3.0.0.6
Location: Original location file found here http://adrynalyne.us/files/patches/car_cradle_patch.zip
Flashing: Car_Cradle_Patch
Other Mod Name: AOSP Lockscreen! now with and without haptic feedback!
Designer: amosher13
Summary:
Pre-requisites:
Other Mod Name: Stock EB13 Theme with Battery Mod
Designer: Paul627g
Summary:
Pre-requisites:
Tools Required: Flash in CWM v3006
Flashing: Android Central
langj
11
install
When we get eb13 will we be able to dump it on the flash card to install or is odin needed. I am on mac so I cant use odin. Hope their is an option for us windows haters. :)
Reactions: tomy2001
traumahawk
303
19
now... i want to flash genocide.. i think... i dont know if i did it already or not. is there a way to check? (i looked at the "kernel" section of about phone... and it didnt say genocide, just looked like normal numbers. what is the kernel name for genocide .01 so i know if i did it right? >.<
Reactions: tomy2001
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
You won't find any change in the kernel numbers. Download either the recommended app from the dev of the kernel or the one that Ragnarokx gave as an alternative from the Market.
BTW, if you flashed it in CWM then it almost certain it worked.
Reactions: tomy2001
traumahawk
303
19
problem was i didnt remember which flash was my last flash. i was having problems with it (and was doing it at like 4am) so i kept flashing and reflashing and dont remember where i finally said "screw it". setcpu showed me as using the kernel from team viper.. which i know is genocide though. thanks :). (and thank you for finally compiling all the roms and themes and such into one post. it was MUCH needed, and very appreciated.)
Reactions: tomy2001
nmoreman
404
17
I would also thank this post as a sticky, a one stop shopping list of new developments. This will be great for both the developers and the users.
What I would also suggest - people (like myself) who will have questions on which kernels, roms to apply to our various setups - ask those questions, and search first. This site should be left solely to informational providers, updates, and even links to other sites.
If we start asking questions, it will become too long and less useful to keep up with, so please search, I already see multiple threads of redundant questions.
Check and know what you have one with your phone, hopefully you kept your backup files, Odin files, or whatever else you might need to change or update platforms.
I know our developers are using the new source code, so I am patiently waiting for their release. Asking when won't make it happen any faster.
traumahawk
303
19
agreed. im guilty too.. but its a good idea. this forum shouldnt be accessible by general users. just moderators and the original poster to be able to keep it updated. otherwise it will get flooded. guaranty.
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
I agree this thread should be closed so I stop checking it when it is shown as unread with no updates.
Other than the one kernel that has been released from the source code on Friday there would be no reason to think that any ROMs have been built and released seeing how the official release of EB13 hasn't even started.
Reactions: tomy2001
anon(49580)
Active member
Aug 17, 2010
32
3
I'm hoping he means to lock the thread so everyone and their grandmas moding uncle can't post. Then if we check and it is unread (bold) we can get REALLY excited because it will mean there is new info on a ROM or EB13 cool thingamajigs...
thats what I'm hoping.
Reactions: tomy2001
shirlysmith44
