Is it possible to block certain phone numbers on the Nexus 6
Aug 5, 2015
10
Directly through the Nexus 6 not that I'm aware of. There are a few apps you can download that will block them for you such as Call Control - Call Blocker. I had the same issue and I used this service to block calls.
anon(9072051)
1,242
Maybe the following article is worth lookin' thro':-
How to block a phone number on your Android phone | Greenbot
This Greenbot author needed to do a bit o' research before suggesting that all android phones have an Auto Reject option. I think that is a Samsung/Touchwiz option. HTC also has a block caller option built into Sense. But no such menu option shows up on my Nexus 6.
planoman
3,605
94
Not in stock android. My s6's have it. There may be a app that does it but stock android evolves slowly...
Posted via my S6 Active!
Emperor
269
4
18
I use the "All calls to voicemail" option that is built into the default Nexus 6 Contact app. I created one contact called Rejected and selected "All calls to voicemail". Next I simply add numbers to that contact. I think I have 15 numbers added to that contact. Whenever someone calls from one of the added numbers, they are sent straight to voicemail without ringing my phone.
cbloom
