kndred79
my phone has had the same problem, are they going to put a ota fix for it?
Sent from my SCH-I535 using Android Central Forums
I am having the same problem. If I go into gsam battery monitor, and look on the list of apps that are using battery, Media is at the top. Click on it, tap in Manage, and Force close Downloads. That seems to help - until the next reboot. Then Media (which according to better battery stats is really media scanner service) just starts running and won't let my phone sleep. Battery drains really fast! My GS3 was perfect before, now this is driving me crazy. Anyone have a permanent solution? I tried a factory reset (twice), reformatting my sd card, and a different reformatted sd card. No difference.Does anybody have any knowledge about "Media Server" and "Media" showing heavy background battery usage?
You need to find dormant mode in the settings. I have yet to find it but I know it is there. Someone posted that you download quickshortcutmaker and search for blocking mode
- - - Updated - - -
On the siii. Go to settings and then sounds. Go to vibtation then change the text vibration. It will change it for all texts not just at night. I had to fix it that way on mine. Hope that helps
Hi, I'm having the EXACT same problem. Initially my phone began freezing, but I thought it was because it was due to me not waiting for full installation to occur. Now its been 5 days and I cant even use the phone. S3 freezes few minutes after my phone reboots. For like 10 min even during restart it would freeze with BLACK screen as if battery had died.
Anyone knows any solutions to this problem????
For those with Battery Issues have you tried changing the cell service back to CDMA/LTE from the Global Mode that it enabled? That seemed to help me.
Anyone able to replicate my calendar widget issue where it my screen glitches when scrolling left to right from the home screen?
