mightyfacundo
I really don't have any concerns regarding the Note 2 and its SD card support. I only use the SD card to store some media files, documents and nandroid backups (then copy them to my home NAS for backups). I plan on using the 32GB SD card from my Thunderbolt in the Note 2 of which I'm only using may be 2GB of it. Otherwise, the 16GB internal storage space on the Note 2 (and my 16GB Nexus 7) is more than enough for me as I average a little over 1GB of storage use (Don't play games or use any apps that require a lot of space).
I'm also content with the version of Jelly Bean the Note 2 is shipping with and am not concerned whether it gets newer versions of Android and how that may affect the SD card. If it does get newer versions, I'm confident Samsung will keep things working well with the SD card. If that turns out not to be the case, I have no problem staying on older software and disabling OTA updates; something I just did with my Nexus 7 in order to stay on 4.1.2 as I don't like the changes for it in 4.2 nor have any use for 4.2's new features. Anyway, that's my 2 cents.
Thanks. What you say makes absolute sense, and I appreciate your feedback. :thumbup:
Sent from my ASUS Transformer Pad TF300T using Android Central Forums
