afrozeke
Only bug I have is attentive display. I don't think they should have held up the release just for that.
Does clearing the Moto X system cache erase everything you have?
For me google play services was a HUGE battery drain, 2nd or 3rd on the drain list. I u installed play services updates, rebooted and now it's at the bottom of the list after a full day.
16.5 hours total, 5:29 SOT and 21% battery left.
Ahhhh, back to normal
So,
- You are able to open Facebook using Moto Voice ? Mine just announces "Opening Facebook" and nothing happens.
- You are able to send WhatsApp messaged from lock screen ? Mine just get stuck on the ambient display screen.
- Moto Meeting is triggered off your exchange calendar ? Mine does not !
- Priority mode = silent mode for you except for starred contacts ? I get WhatsApp sounds through.
- Bluetooth audio connection is ok ? Mine is patchy but still livable than the bugs mentioned above.
If its just the attentive display you are facing - you are one lucky man !
PS: All these bugs, after 2 factory resets and 'x' number of cache clearing, where x = I really lost count times !
Apart from the attentive display issue which i fixed, i find the following buggy...
I cannot open any app on voice prompt command when the phone is locked. When its open, im able to access apps. I dunno if moto voice has to be tweaked according to new OS.
Another lousy thing is Whatsapp keeps beeping when I switch to priority mode. And moto assist has synced with downtime settings in android l, but honestly i dint quite understand how interruptions and priority mode works.. I made sure all apps have priority turned off.. including whatsapp. But still whatsapp notification beeps. that just threw me off, wondering what was i doing wrong....?
Also in priority interruptions,there is an option for events and reminders. I know reminders but what it means by 'events'? Just to make sure, i switched it off too (I switched off calls and texts..).
Im kinda irked by how the phone goes to 'priority' mode when i activate sleeping in moto assist. Maybe they should have snuck in an option there.. or maybe its just me not used to the new stuff .. I'm thinking Android L tried to implement some of the 'assist' features from moto here
For your Whatsapp issue go to Settings>Sound & Notification>Interruptions...at the top of the interruptions tap on "When Calls and Notifications arrive" and select "Allow only priority interruptions" and see if that helps correct the beeping issue. My was defaulted to Always interrupt and I think that overides the other interruption settings. Hopefully that helps.
60% radio 40% WiFi.Nice thank you
What's your wifi/4g ratio
