I posted this in another thread, didnt get much feedback. One of the amazon cases for the Bionic had dimensions on the Case: Amazon.com: Motorola Targa XT875 XT-875 Black Rubber Feel Snap-On Cover Hard Case Cell Phone Protector: Cell Phones & Accessories
Product Dimensions: 5 x 2.8 x 0.5 inches ; 1.4 ounces
Quick Comparisons:
Droid Charge = 5.11 x 2.66 x .46 in.
Thunderbolt = 4.8 x 2.6 x .51 in.
Droid X2 = 5.02 x 2.58 x 0.39 in.
Revolution = 5.03 x 2.63 x 0.52 in.
If this case dim's are accurate then the Bionic isn't any bigger than the other 4.3" phones.
Actually, it's noticeably bigger. Looking at cubic inches (the total amount of space it will take in your pocket)...
Droid X2 - 5.0511
Droid Charge - 6.2525
Thunderbolt - 6.3648
Revolution - 6.8790
Bionic - 7.0000
If the specs are accurate, the Bionic represents 40% "more phone" (take that any way you want) than the X2 for the same screen size. That's a big freakin' phone!
I find the Thunderbolt pretty chunky, but the Bionic would be 10% beefier for the same size screen.
Hopefully, it's just a matter of measuring case sizes vs. phone sizes, which I suspect it is.
I believe that the thinkness measure for the Bionic has been taken where the "hump" is located, so that isn't representative of the entire phone. Can't tell from your calculations if there was any adjustment made to your measure or if it was assumed to be the thinkness of the full length/width of the phone.
I cannot release that info. Not trying to be evasive, PM me and I will give you more info.Says who?
