When I connect the phone with usb to pc it becomes automatically visible in the filemanager (but sometimes not!)
Problem is that sometimes the pc just can't read the phone, crashing the filemanager. Another problem is I can't edit my notes (.txt files) my notes app has generated. I need to copy them to the pc first, then edit and then paste them back.
I had none of these issues on galaxy ace, when I would just click the usb option to connect (mount) the sd card to the pc. no problem. But on this phone there is no option to disable this 'automatic' connection, which seems to not work properly.
I've tried the camera mode and the file mode. both do not solve the above problems.
Is there a way to manually mount the sd-card to pc? (slide top > usb options > connect phone to pc)
Samsung GT-I9105P
Galaxy S2 plus
android 4.2.2
Samsung GT-I9105P
Galaxy S2 plus
android 4.2.2
