My Google Nexus 7 won't turn on! Tried everything! Empty battery icon.
adamislip
Hi. My Google Nexus 7 tablet is stuck in some sort of standby mode. It's been charging for almost 17 hours now and when I try to switch on (including holding down power button and volume and/or down for 30+ secs) I just get a blank screen and an empty battery icon - or 5 flashing white lights.
I have scoured the net and can't find a solution - I've tried charging via my laptop, holding down the power and volume button together, unplugging and reinserting the charger, clearing the charging port... but I'm drawing a blank.
Please can anyone help!?
GSDer
8,471
15
You've tried different charging cables?
It's possible that the micro-USB port is buggered up; it does support wireless charging, so you could try that as an alternative.
adamislip
I have tried different cables, yes, although none of them are the original cable. But I've tried charging straight from my laptop but with no joy. How do I charge wirelessly?
GSDer
8,471
15
You just need a wireless charging pad. I don't remember offhand which standard this thing uses but I'm sure you could find one on Amazon for cheap.
Just need to remove a case if it's more than a couple of mm thick.
