Updated:
Well, I currently have a Google Edition of the HTC One and I was a little disappointed to find out that you couldn't pull down the notification shade from the lock screen if you have security enabled. I think I might have just misunderstood something on that I read a while back.
It turns out, though, that you can access the lock screen widgets though when locked. As such, I think I just found my new favorite app for stock android (since the S4 with Touchwiz blocks the ability to use lockscreen widgets at all if you have security enabled): NiLS Notification Lock Screen. I was previously using Dashclock and while I liked the extentions and look, it just doesn't show notifications for everything I use. You need to find extentions and there are still plenty missing for many apps. NiLS on the other hand pretty much shows everything and supports notification shade syncing in 4.3. Even look good too and has some basic customization options. My main reason for wanting to be able to pull down the notification shade was for my quick toggles (Notification Toggle is the name if you're curious as to what I'm using) and thanks to NiLS I can add it as a persistent notification on the lockscreen and access them. Beautiful.
