why flashing the my ipad
Welcome to Android Central! Do you really have an iPad? If so, go to the iMore forums. iPhone, iPad, iPod Forums at iMore.com
Tablet won't turn on - i changed the batry and press 20sec for reset HELP!
so my nexus7 tablet wont turn on for me even tho its fully chargerd and i even hld the button down for 60 seconds like my dad told me to and the first 4 days i had it, it was working fine but now it wont even tell me if its charging:'(
Have you tried holding down the power switch until the screen comes on? You might have to hold it down for up to a minute.
Sent from my Galaxy Note using Android Central forums
Just got the shock of my life! Went to turn the tablet on and guess what? I wont come on! PLEASE HELP!!!!!
Good idea, buuuuuut....There is a solution to this. You can wipe the flash memory completely and re install stock android. (this requires a bit of knowledge) Note that resetting the device to factory settings will not help.
The other easier method can be found here: http://forums.androidcentral.com/go...do-you-have-laggy-nexus-7-heres-solution.html Cyanogenmod is stock android with some of the 'bloat' removed and advanced options enabled. And the installer does EVERYTHING for you. So anyone can install it without having to worry about rooting the device.
You can do this and keep using your 2012 N7 without dropping money on the 2013 version.
