Nokia 6 TA-1025 on Cricket Wireless: "error 10" when attempting to send SMS messages
TarttApple
3
Title explains most of it. My Nokia 6 is unrooted, a few months old, carries a Cricket SIM card... I've recently gotten this error repeatedly and seemingly out of nowhere when I try to send SMS messages, so I looked it up, gave up and figured that restarting would be the way out... as it normally is.
It wasn't.
I turned on my light, spent half an hour trying to look for my SIM slot unlocking thingamajig...only to give up and use a pushpin, which worked. Took out the SIM, reinserted, restarted. That's fixed pretty much every SIM problem I've ever had, at least temporarily. No, not even that worked...so I updated my phone to the latest available software update; even though it was just security-related, I was looking for an answer. That didn't work either.
So here I am, making a post on Android Central for the first time.
Occurs almost immediately after texting a message or attempting to resend one. I've texted multiple people, and the same result shows up. I haven't seen this exact issue before, so I hope we can work to find a solution!
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,394
255
83
re: Nokia 6 TA-1025 on Cricket Wireless: "error 10" when attempting to send SMS messages
Welcome.
Have you also spoken to your carrier about this?
TarttApple
3
Well, after hours of testing, it seems to work perfectly fine now. I'm still not exactly sure what error code 10 is supposed to mean, but I guess it's over now? Figured it'd be a client-side problem, but again, I don't know. Thanks for the reply.
belodion
Moderator
Jun 10, 2014
39,394
255
83
I assumed it might be a carrier-related problem, or bad SIM, therefore worth checking those things first.
Error 10 can I believe be caused by a blank text message, or one that exceeds the permitted number of characters, a couple of things to consider perhaps should the problem recur. But other things may cause it for all I know.
Anyways let us know if you have further trouble.
thephilster001
