OEM Car Charger
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
As long as your the car charger you have purchased doesn't go beyond what the manufacture recommends for voltage you should be okay.. Not enough volts will only result in things like using your phone for say GPS and expecting it to keep up with the charge and battery drain. Otherwise you should be good to go :)
