[Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
Just so you know, you don't have to wipe anything before flashing the zip. Its just replacing some files. I flashed it without wiping anything and I have no problems.
Reactions: nitestalkr
nitestalkr
889
261
Thanks for providing that information, I'll keep the current procedure, but make wiping optional.
sent from my un-dead sammich.
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Re: [Guide][Port][WIP]Porting ANY OptiS rom to the OptiV in 1 Fla
I'm sorry, I should have posted in the other thread, was talking about getting the MMS fixed in your Jellybean ZIP. :p
ilikechicken123
420
113
The zip didn't fix my MMS. But I didn't try the thing in the link.
I tried sending myself a pic and after a while it still said 'sending' on JB
edit: I just remembered xD MMS doesn't work in JB yet.
ThatGuyLurkin
2,155
665
yessir.
I'm still seeing if any extra files need to be added to get data working on GB, but it seems to work on ICS and JB as is.
Actually. The 3G isn't there because the phone became unactivated. We need to see what the activate app does to apply it to GB. :/
I flashed back to ZV5, thanks to Sammyz, and I had to reactivate the phone. That's all that's missing.
nitestalkr
889
261
So on GB Optimus S roms, just reactivate, and data works??
I'll add that tto my guide in the OP
andrewnelson23
795
145
The activate app. which only works in froyo :mad:
question. if you reactivate, do you have to upgrade your plan? I'm on 25/month and don't wanna go up to 35/month...
andrewnelson23
795
145
Nitestalkr, on your fix zip, could you edit the build.prop fixes that clodfeterac put on the other thread that changes how the play store sees your device? :)
nitestalkr
889
261
Your plan wont change.
Its only changes if you're swapping to the newer phones, you can actually swap to a replacement Optimus V, and keep you're 25$ plan.(I've tested this with my V that has a broken screen... I was without a functional phone for 48 hours cause the screen doesn't work lol, But, I did root it while its like that xD)
cottoneyejoe
