My phone icon is missing on my phone
This occurred with my amazon kindle icon went AWOL after a system update was done. I could not find it in the application folder only in the application manager so the above posts were useless.
SOLUTION: (at least for the Samsung galaxy S3)
After entering into the application folder (APPS - see GSDers post above) , tap the menu button (on the galaxy s3 it is the touch button on the far bottom, to the left.)
You will see a menu list which starts with PLAY STORE. Here is why you have problems. there is a last folder named SHOW HIDDEN APPLICATIONS which is not visible until you scroll down one last line. open that it and you will see all icons including your lost one. highlight the check box next to it. THEN PRESS DONE AT THE TOP RIGHT (NOT THE BACK BUTTON ON THE BOTTOM RIGHT = FAILURE.) Your icon will now appear in the APPS folder and hold and move to your Active pages as GSDer clearly noted above in his post.
I struggled with this for a couple of days and finally regained my Amazon Kindle Icon with this process. Good luck.
