Phone stuck on error message, please help.
A
AC Question
Ok, so a couple of days ago I attempted to root my phone using odin. While it was rooting my phone, all of a sudden odin said 'removed' then my phone just restarted. After it restarted, it came up on a screen that says 'An error has occurred while updating the device software. Use the Emergency recovery function in the Smart Switch PC software.' So I downloaded the software but when I plug in my phone it says device not recognised. So from there I decided to download the original firmware and install in manually onto the phone using odin. When I get the phone into download mode and click start it just fails. It doesn't say 'removed' just stops at NAND write start!! and then FAIL! I noticed on the phone after if fails on the download screen it comes up in the top left corner in red saying 'SW REV. CHECK FAIL. DEVICE: 3, BINARY: 1'
Please, could someone help me :C It's a brand new Samsung S6 SM-G920F on Three.
karim174
