Worked for me also. Thanks.Turning off Google history tracking worked for me.
Sent from my LG-H811 using Tapatalk
Have you tried this, "Actually I forgot but I ran into that too, turn off Android device manager and go back and try again. That's a play service too."?
I too am unable to uninstall Google Play updates (not an option), and I saw where someone suggested first turning off Android Device manager, but I can't even find that to try and turn off. Where is it?
Also, I was going to disable Google Fit, but I cannot find it anywhere on my phone.
Thanks.
I was referring to the dministrator privilege for Android device manager. I'm not sure all that's necessary now though.
Try this instead; turn off all smart unlock options under lock screen, smart lock.
I don't think that will work for me as I have my screen lock set to "None."
Same here but I have mine set to swipe. Smart lock is greyed out, not accessible. Does this mean that I have all smart lock options disabled already?!?
My guess would be that, if your phone unlocks with just a swipe, then Smart Lock would presumably not apply.
