Hi all,
I have an Optimus V on Optimus S firmware. I know what you're thinking: what the heck?? Well, I actually get better service on zvd and I'm convinced I get better on zvj while I've briefly used it on stock. But also, I can run basically any Optimus rom on zvj.
But before I can do that, I have to first root zvj! So I have zvd rooted. I've tried this using both gingerbreak and the optiauto tool. Both of these worked and I definitely had root!
I started on rooted stock zvd.
Next, I used the Optiauto tool to install the zvj update.zip. After this I re-enabled debugging and booted to recovery again using optiauto. Then I installed the update.zip. This gave me the expected error exactly. After this, I ran the exploit on optiauto(the last step to root zvj).
This is what I got on the command prompt.
On my phone in recovery, I got
This did not install root for me. I've tried it multiple times.
Can anyone help me?
Code:
Installing persistent root... write: No space left on device
Done
Waiting for filesystem to sync... Done
Installing Recovery - Xionia CWMA... write: No space left on device
Done
Installing Misc - Clean... write: No space left on device
Done
---- END LOG ----
Code:
E:Can't find command file CACHE: recovery/command
Installation aborted. no valid image in CACHE
Can anyone help me?
