ARCHIVED: [ROM][4/05/12][4.0.3]MIUIv4 for OV! By Team A.P.P
Status
Not open for further replies.
reaper420
215
21
Re: [ROM][ALPHA][4.0.3]MIUIv4 for OV!
has anyone discovered a way to remove that "roaming indicator is not on" out of the status bar. it sticks out and is kinda annoying
terthii
226
33
So...I'm on the new V. Flashed alpha4 and the iScream kernal...can't get data. Also, I can't get wifi to work either.
colossus3874
97
7
I also can't get 3g no matter what I try. No amount of giggling works for me. If I can have 3g, I would use this every day
rukin5197
1,105
628
Guys, I removed the iscream kernel from the OP. I guess I don't recommend it now, because it is causing MAJOR 3g issues with people. So if you have it on, please do a full wipe and test again
bornagainpenguin
204
19
18
If I can make one suggestion, it's this: Make it a priority to remove the privacy wipe or factory reset ASAP! You know that sooner or later someone is going to hit those options without thinking about it and "brick" their phone, blaming you. Best to remove them from the settings and prevent the whole thing right from the start.
--bornagainpenguin
terthii
226
33
I'll try reflashing without the kernal later. Had to restore my BACKside backup because I needed a working phone.
Status
ukfred
