ARCHIVED: [ROM][4/05/12][4.0.3]MIUIv4 for OV! By Team A.P.P
Status
Not open for further replies.
CuriousNoob
Banned
Aug 2, 2011
1,590
202
I wish I knew. Was just suggesting it in case it was a part of the original R0M and you just hadn't gotten around to removing or hiding it yet.
I don't know how to program, sorry.
Every MIUI rom i ever user had Factory Reset on it....
You teach me how, I'll remove it immediately
thewraith420
1,987
223
63
Tdm removed it from quatrimus and none of the iho roms have it perhaps you could pm one of them for help
rukin5197
1,105
628
Re: [ROM][ALPHA][4.0.3]MIUIv4 for OV!
I'm sure I'm going to have to decompile the settings.apk and manually remove it.. but it shouldn't be too hard
BTW: if anybody wants to see updates of my newest ROM ports, I made a blog :)
This should keep you up to date and it helps, instead of making multiple multiple threads for each of my ports.
http://www.gannon5197.blogspot.com/
It's brand new, so it's a little bad looking, but it's still functional :)
Reactions: 00_wrath_00
reaper420
215
21
has anyone been able to get a theme to work on this, i guess im doing something wrong it always says the theme is applied, but nothing ever changes, were exactly is the themes folder supposed to be exactly.
rukin5197
1,105
628
Check the op
Sent from my Amazon Kindle Fire using Tapatalk
colossus3874
97
7
I did a fresh flash, making sure it was the Ginger kernal and still can't get the 3g running. I'm sure it will get there but I need data so back to another rom for now
theexile1
143
9
hey gannon is the problem with phone in the lib files or did you use the origanal ones??
theexile1
143
9
is there any diferances between the ones from them and the ones from quatrimus? but that wouldnt cause a problem with the phone if it was the origanil so wat did you all change???
theexile1
143
9
is there something colliding with it? you said it doesnt happen till theres no service maby look at the thing that controls the service maby make the fone think that there is always service?
samlin168us
Active member
May 2, 2011
34
4
3g working without 3g icon.. I can browsing webpage but can't download apps from market. Can't use speedtest, groove ip,,, so weird.
Sent from my VM670 using Tapatalk
Status
Abdul Ali
