Clean flashed 0930, with formula's gapps 929. Performance seems very good. Will be watching battery... Stock kernel.
NO! In fact they might not take anyway if you have the google apps installed already, BUT if your coming from a CLEAN install then you can use them, not necessary though.Are the addons necessary?
I'm curious if this update add on will be solely for the "official" CM10 or if Euroskanks will be included, I guess we'll find out tomorrow!
Anybody notice this??
"If you're using the CyanogenMod team's custom ROM on your Android device, and are running any of the nightlies from today (Sep. 30) onward, you now have a new option in your settings -- CM Updater. What it does is give you the option to automatically check for updates and install then, just like an over the air update from your carrier. We've seen this done before from other developers, and from ROM Manager, but now there's a built in option for all users of the ROM".
I'm confused...does this mean that we'll be able to cleanly install nightlies without wiping data (like an OTA upgrade)?
Further, would that only work for the official CM10, or will it also work if your running EuroSkank?
(Euroskank is the best Daily out there by the way, imo)
I feel the same about skank's nightlys for aokp. I think its even better than the official.
He has them for AOKP? Didn't know that, got a link to that?
It's Dre Beats awesome.
http://img.tapatalk.com/d/12/09/29/utazeny4.jpg
Beamed from the future via Tapatalk
I flashed the "Awesome BEATS" (aka DSP Manager with a new icon and a few words changed ) via the link you provided (thanks) and I've found my initial positive impression to be a placebo effect. I use an aux port via the headphone jack to play music in my car rather than BT and even though the sound was very much better than stock the settings didn't do anything. Changing presets, compression, bass, etc.....zilche. Just me? DSP worked perfectly so I'll be reflashing that again. Second question, any idea if both zips "live" in the same place and will overwrite eachother or do I have to nandroid to get rid of BEATS?
I know what ya mean, I think it's more of a headphones thing with dre beats to tell any (if any) differences. Just flashing the next nightly would probably be the best bet.
Tapatalk sent from the future
Flashed the newest 1002 update and saw a "cannot find ghost.cm". Anyone else get the same error at the beginning? Anyone know what it means?
About to flash this now so I'll look for that, (and yes FActory Reset=Clean Flashes are the way to go)
