[ROM][ICS] the GODZILLA ROM 10-20-12
ThatGuyLurkin
2,155
665
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
Is it a GSM phone?
Sent from my LG-LS670 using Tapatalk 2
I don't really know if that matters.
TBH, I don't know what they are, but understand GSM, CDMA, Etc.
I recently learned CDMA is known for good calls and GSM is fast, but drops calls often :p
flapjack.fiasco
776
102
I could be wrong, but I think dropped calls have more to do with carrier than anything else. GSM uses sim catds, while CDMA does not. That's the real difference as far as I'm aware.
TaylordKris
Active member
Jul 20, 2012
39
Quick question, everything works perfectly.
however, I've looked all over, or maybe I'm just overlooking, but is App Drawer on here? I want to hide an app, but I can't seem to find where it is!
thanks!
Nico72
55
16
thanks!
That has to do with the launcher app your using. I would suggest Apex or Go Launcher.
A-android-B
414
21
thanks!
Sounds fairly hidden lol -sorry I couldn't resist
chuchuthenigg
love the rom only one problem, when i listen to music it crashes then skips to the next song. everything else is awesome but can you fix that? im always listening to music off my phone and it gets annoying when it does it. thanks great job btw
Encerspay45
619
32
Does this include the a2sd scripts like in Quattrimus and Cold as Ice?
Because my partition is FAT32, these built in scripts are the only thing holding me back from taking a big bite out of this ice cream sandwich!
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
thanks forusic I will flash and see what you mean
it works the same your partition will be put into play
@me
My first multi quote lol
Encerspay45
619
32
@me
Yay jonny and multi quote! :)
I've just been having trouble with CM9 because my partition is FAT32, and it doesn't get recognized.
Does that happen here, too?
ThatGuyLurkin
2,155
665
Why was the S version archived? You don't even have a V? o_O
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
I couldn't handle 2 roms exactly the same so I just decided to continue this one as it was developed first.
Either s or v I'm getting an elite very soon
Avenged $evenfold rocks
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Needs to be ext2,3,4
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Picking this back up......
Have some ideas no info on a release date it will be soon
ebrown761
Active member
Jun 18, 2012
31
Very easy to do and i did it in like 10mins and i dont really like command prompt, i used this instead of having the recovery do the format because as i recall the recovery would only format it to ext3 where as with this you can format it up to ext4 which is a little faster. Help with memory card formatting via usb using windows command prompt. Background I've flashed my phone and my gf phone several times, on her phone Dev of roms has all but shut down, she's on the boost replenish and the rom is PhoeniX ROM 0.2 when installing that rom i happened to stumble upon Firehaks guide to formating sd cards View attachment ReplenishDataPartitioning.pdf either ext2, ext3 or ext4 using windows command prompt. only do steps 1-9 the rest pertains to Replenish only. Hope this is of help. And make sure if you need anything off the memory card to transfer it to your computer.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Anyone wanna test since I don't own a V
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
1am, huh? Ugh, fun times indeed! Glad you got them though!
Your G-1 first look video today was great! I love that you can add Folders to the Home screen and put stuff in it like your games. Sweet!
OK will send to you when I can:)
ThatGuyLurkin
2,155
665
Hehe, Random quote ;)
Quote from 2008!!!!! o___o
