Re: [ROM]MIUI 2.3.7 Release4 4.14.2012 ZVD
Settings crash is a known issues stated in the OP. Most might stay that way since this is a port and most cm7 settings don't exist but they show up in the options.
Browser is working fine on mine. Use an alternate browser instead if its force closing on you.
reason I didn't delete sidekick is because long pressing search button and swiping left brings up a task killer.
Thanks for pointing out the camera crash, I didn't check it. I'll include the previous version next time or just attach it to the OP, so you could push it to apps using root explorer.
Regarding PRL and PROFILE update, flashing a custom ROM doesn't change your PRL or Radio and to update it you should be on stock or stock based ROM. Reborn works since its for ZVD (which you are on currently).
working awesome so far thanks!
few things to report:
system/device settings crashes
program/browser crashes
the voice button above the camera button acts as another power button...cool haha
Camera keeps crashing but video works :-\
i dont know what's going on but I would like to get rid of the chinese search pop up when i click the search hard button. is it possible to set it back to google search?
edit: hmm nvm i just straight up deleted sidekick and installed google search and that took care of it...hope it didnt break anything!
is it not possible to update prl through miui? my signal looks to be a little weak.
i saw on post 72 that it was stated we should try going to reborn to do it and then reflash miui if there were any data problems...if you don't mind enlightening me on the subject: i just assumed "prl" and "profile" were things that would be cleared when flashing roms and wiping system/cache and stuff
