froir
Active member
Ill do it for you if you want me too?
I already did man. Thanks anyway.
Rotation issue still exists. Ahhh
http://phantomphreak.shabbypenguin.com/files/CM10/cm-10-20120820-UNOFFICIAL-epic4gtouch.zipLink?
Enjoy the download speed Shabbys server is stupid fast
If you know how to pull logs in case you run into any errors, please post them here. If not, its ok. EnjoyBT stereo is working beautifully! and, the DSP manager is working without a hitch which I couldn't say in AOKPM6. no los, no airplane mode bug, auto rotate - responsove, no bugs to report in the past 20mins of playing with it lol.
I've never done it b4 but I will try. . . type " logcat > /sdcard/logfile.txt " in terminal right? then post the log file?
adb shell dmesg > dmesg.txt use for logging kernel issues such as LOS
adb shell logcat -d > logcat.txt random app FC's, sluggish behavior, etc
adb shell cat /proc/last_kmsg > last_kmsg.txt use if you encounter a random reboot
su // dmesg > /sdcard/dmesg.txt
su // logcat -d > /sdcard/logcat.txt
su // cat /proc/last_kmsg > /sdcard/last_kmsg.txt
Just curious if anyone else has had issues with the phone not waking up when it's sleeping? I've noticed that if I let the phone sleep (disable led notifications and unplug from charger), it won't wake up. I usually have to press and hold the power button to do a forced reboot on it.
Devs: Is there anything I can do help you with the diagnoses?
Are you sure? Its really fun
Send me the edits you make and I'll take a look.
If you're nearby a computer and have adb installed, then methods are
If you dont have adb installed, just open the terminal emulator app in app drawer " // " = press enterCode:adb shell dmesg > dmesg.txt use for logging kernel issues such as LOS adb shell logcat -d > logcat.txt random app FC's, sluggish behavior, etc adb shell cat /proc/last_kmsg > last_kmsg.txt use if you encounter a random reboot
Copy the text onto Pastebin.com and post link here. This will be a bit tricky if only using your phone.Code:su // dmesg > /sdcard/dmesg.txt su // logcat -d > /sdcard/logcat.txt su // cat /proc/last_kmsg > /sdcard/last_kmsg.txt
