Rooted with MotoFail, will i keep root after .905?
Hiphiphooray
Active member
Sep 15, 2011
32
I rooted like a month ago on motofail, and now I can update to .905. If i update will i keep root, or have to reroot? Should i use OTA voodoo (if so, can i get a link)?
Lee_Bo
929
58
28
If you use the 4ever root method, you will keep root to .905 because that's what I had and I kept root. If you lose root after .905, just use Motofail. I've heard OTA Rootkeeper works but have not used it personally.
kamisan
if you go all the way to ics ( version 230 or 232). use razors edge root method.
Sent from my DROID BIONIC using Android Central Forums
Hiphiphooray
Active member
Sep 15, 2011
32
I still haven't updated yet. I couldn't see that link because I'm not a registered user. :/
anyway, should i just take the update and if my root is lost reroot with motofail? this seems easy enough.
or if i use forever root, do i do that first then update or after the update?
ukfred
