Has anyone gotten their notes from an original Note 10.1 to sync over to the 2014 Note 10.1? My Notes are showing the cloud icon in the corner and my sync settings are indicating that a sync is taking place but my notes aren't showing up.
There's no issue... You CAN use your older notes in the Note 10.1 2014, you just have to import them (they won't sync automatically at first). However, when you import them you will notice that the software tells you it's converting them to the newer format. This means that the notes you create on the Note 10.1 2014 (or an S4 or Note 3) will NOT be compatible with older versions of S-Note.
From what I have read, there is a big difference with the DOC vs DOCX analogy in that newer versions of office can read DOC files without converting them to DOCX and they can save the documents as DOC files. The new Note converts the file into the new format and renders it unusable for older models. This would present a problem for group projects unless everyone is using the same version of the Note.Granted, but that wasn't the issue in the OP But yes, whatever you do in the new version of S-Notes does not become editable on older ones. But again, this is a new version of the software, so you can't really expect backwards compatibility. I've made this comparison before but it still applies: You COULD expect PS2 discs to work with a PS3, but you CAN'T expect PS3 discs to work with a PS2. You can play a DVD in a BluRay player but not the other way around, right? You can open DOC documents in newer versions of Office but not DOCX files in older ones. Same thing here.
