S7 edge charging issue
anon(5630457)
2,082
My S7 edge will sometimes disconnect and reconnect to the OEM charger as it's charging up while I'm using the phone. I'm not noticing any bent pins in the charging cable. Any ideas why it's doing this?
IAmSixNine
3,157
72
My guess would be that you have done this quite a lot, use the phone while its plugged in, that added usage while its plugged in has probably caused added stress to the data port and loosened the mechanical connection between the data port and the cable.
Try a different cable. If you get the same result then your data port may be coming loose or damaged.
andej
