Samsung S7 edge download mode unavailable
Aug 16, 2022
19
When I try to use the combination of volume down + home + power key to enter download mode it fails. As long as I push the keys down, nothing will happen and as soon as I release them my phone will restart and then go to "installing system update" and after a while it also fails with "no comment" error. The whole process start again. I can't turn off the phone. As long as there is battery it will go through this loop. Naturally there is no access to other modes like safe mode or recovery mode and there is no way to enter the android OS.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,653
6,229
113
What did you do previously with the device?
You already Trip knox and looks like you installed custom firmware.
My other question in Odin you using different firmware in bl and csc ? They all need to be from same firmware dont mix and match
These are your screenshotsScreenshot_20220822-124924.jpgScreenshot_20220822-124803.jpg
shirlysmith44
