HOME_WORK
Thanks, I'll check the link and if something goes wrong I'll post it here. ^_^
Sent from my LG7?VM670 using Android Central Forums
Okay ill stay away from rooting for now, and come back to it when I know more about it.
Thanks for advice
Sent by my cat using LG?VM670
I had the exact same thing happen to me, and I just fixed it like 3hrs ago. My problem was that I accidentally turned off USB Debugging. After I turned it back on everything worked again.
If your USB Debugging IS ALREADY ON I would try turning it off and back on. If none of that works then I have no idea how to fix it.
Sent from my VM670 using Android Central Forums
