Spare battery
Mar 23, 2013
14
Hi everyone,
My new GS4 should be here tomorrow but I wanted to ask in advance regarding a spare battery.
I have looked around but can only seem to find batteries for the I9500 version. As I'm in the UK I'll be getting the I9505 version.
Also, I'm getting the Neo Hybrid case so a "larger" battery won't fit.
Can anyone recommend a battery from a UK source at all please?
Regards,
Michael.
AlphaVictor87
818
5
If anyone here in this thread also has any clue, i always like to have a spare charger at work. I don't want to order one from samsung, so does anyone know a cable from Amazon that is good and cheap that i could use as a work charger (don't need the wall plug, just usb to micro usb)
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Doesn't the battery for the 19500 also work for the 19505? I'm sure u can get any battery or wall charger compatible for the phone and it should work fine
Sent from my Samsung Galaxy S3 Boyyyyyy!
speed13
371
Any compatability usb cable would work fine. You can find one for few bucks at eBay or Amazon or some local store near you.
Sent from my Galaxy S4 White - using Tapatalk
pedroharoo
