DanPLC
Not sure why anyone still uses Facer. Watchmaker is vastly superior and doesn't impact battery life. Plus there are a ton more faces available on facerepo.com.
well, i used my watch in earnest this weekend and i must say, the battery life is good! i totally drained the battery until it powered off by itself on friday night, didn't put the watch on the charger until saturday 630am or so, took it off the charger at 820am. i used the watch for typical reply to texts, used it for about 10 minutes for navigation, and playing around with watch faces, and of course checking the time. by the time i came home on saturday evening at ~7pm, i had 47% battery left!You should be getting a minimum of 24 hours of battery life with light use. You will not get full battery life until several charge cycles (give it 4 to 7 days). Turning off tilt to wake is a perfectly valid test to see if you are accidentally waking the watch, doesn't have to be permanent.
If after that you are still having problems, check out this: http://forums.androidcentral.com/moto-360/471939-what-do-when-360-misbehaves.html
after i read a lot of negative reviews for wear update, i unchecked auto-update. i'm still on 1.0.xxx. my watch is still on 5.0.2 with build lwx49l.That is weird. I wonder if it had to do with the new Wear app update (Not sure if it's hitting all phones yet though) or if the new watch update has already started.
