I got this case today, and wanted to provide some thoughts, most specifically in how it compares to the Spigen Slim Armor Pro... the other case with a similar hinge protector that this replaces.
If you're interested in making your phone lightweight... use one of these types of cases for a few months, then take it off.
I never knew a lousy 2 ounces could make such a difference, lol.
1) The hinge protector is bigger, protrudes out more, due to needing to hold the SPen. This makes the overall package wider when closed, but not an issue for me, but it might matter to others.
2) I... like some reviewers of the Spigen said about it... actually like that the hinge protector actually makes the phone easier to hold when opened. This hinge protector being a bit bigger, actually makes it even easier to hold than the Spigen.
3) For some reason... I'm guessing due to the various cut out/textured design of this case vs the just flat design of the Spigen... I fumble, and almost drop, the phone every time I open it. I never, not once, had any issues opening the Spigen. Hopefully, with more practice, this issue will go away.
4) For the cut out for the volume/power/FPS buttons, the back part actually has a lip to it, the Spigen was flush over that area. This makes it harder to touch/press those buttons, since at times my finger hits the lip of the cut out, not the buttons.
5) Speaking of cut outs, they all line up perfectly over the speakers and mic.
6) The need for the adhesive strips. I ended up having to use them on the Spigen since the left side of the case kept shifting off to the left every time I opened it. Pro tip, cut the adhesive strip portion that would otherwise cover the antenna cover off so there's no strip there; upper right side. Too many reports of the cover being ripped off when removing the case. HOWEVER, I have NOT needed to use the adhesive strips that came with this case. Again, for whatever reason, there's no shifting or anything when I open the phone, it all just fits, and stays on.
7) A biggie folks here seem to be concerned with. The metal pieces inside the hinge, and potential scratching. There were similar concerns with the Spigen, though the hinge protector is designed a bit differently, it does have some metal. First off, if you have one of these cases, watch closely along the hinge as you slowly open it, you'll see that there's no way those pieces can touch the hinge, they never come near it. Now, the Spigen was a bit different... the metal also never came near the hinge when opening, BUT, if the metal broke away from the plastic piece holding it, it most assuredly scratched the hinge. I followed a reviewer's suggestion, and put a strip of black electrical tape along the hinge... so even if some piece of metal from the hinge protector rubbed it, there'd be no scratches on the hinge. Some people were aghast at putting adhesive/tape on the hinge... to those folks I say... uh, relax, lol
