Can anyone help me figure out what my screen does this?
FISH4RUDY88
17
My wallpaper changes size on it's own. I set the wallpaper picture and after a few minutes it changes size.Can anyone help me fix this? The picture on the right is the way it set it, it changes to the size of the one the left.
mclarryjr
Retired Moderator
Nov 2, 2009
5,474
635
113
It's either your launcher or if your using a 3rd party application to change wallpaper like PicSpeed. This happened to me once and I believe it was my launcher because I enabled my home screen go into lanscape. Are you using a wallpaper app? and what launcher are you using? You could try setting that wallpaper to the Sense launcher and see if that problem happend then even switch back to your other launcher.
FISH4RUDY88
17
I am running Nova launcher. I did try starting it in the HTC sense launcher.It only stops if I turn off the Nova launcher, so I guesss that's the source of my problem. I just wish I could fix it. It didn't do this when I first installed Nova. Well thanks for the help.
anon(924308)
598
As annoying as it is to have a billion tiny apps, you might try downloading a 3rd party wallpaper app. I'm using "Simple Image Wallpaper Free", which allows me to set 1920x1080 images exactly as is.
sarasotatim
18
This is awesome, thanks, I've been looking for something like this for my DNA for 2 damn months LOL
RandyRoyalty
