Results 1 to 2 of 2
    ds28's Avatar
    Posts
    Global Posts
    110 Global Posts
    Default SD card scan/index updates
    I've noticed that if I download an image, for example, or save one to the SD card, it doesn't show up in my photos until I reboot.
    I've also noticed this behavior with a drawing app that saves to the SD.
    Am I missing something, or is there an easier way to get my phone to re-scan/index the files?
    Or is it a problem with my particular SD card?
    Thanks in advance!
  2. #2
    rhippler's Avatar
    Posts
    Global Posts
    66 Global Posts
    Default
    Yea I noticed that too. and god forbid you move something. then you have 2 of everything in the list, except that 1/2 of them don't work right. it does eventually sort its self out though. Just wish there was a easier way than shutting down and restarting.
