Re: [GUIDE] Galaxy Nexus MOD/Palm Touchstone-No soldering on phon
Just wanted to say a big thank you to the OP and the rest of the folks in this thread. I was able to successfully complete this mod.
The biggest difficulty I had was making sure that the battery cover came into good contact with the phone. If you put it all together and it's not working, definitely check your connections one piece at a time. I found out the hard way that the copper tapes inside the phone weren't as solid as they should be so I had to take apart the phone again.
Here are some additional hints to try to help out other folks, esp the more novice electronics folks:
- Learn to use the continuity function of your multimeter to make sure all of your tapes and connections are good.
- Before putting the phone back together, test your copper tape connections by using the continuity function. The easiest way is to put one probe on the appropriate external pogo pin on the outside of the back cover and the other probe on your copper tape where it's wrapped around to the other side. This will ensure you don't have to take apart your phone again.
- Also before putting the phone back together, put together the battery cover (with the inductive coil already installed) with the back cover and use the continuity function to check that you have one continuous circuit from the pogo pin all the way to the inductive coil.
- The foam suggestion is pretty important. Go ahead and use half of the foam for each tape. I do wish I had more foam to use on the battery cover side and automotive foam is pretty expensive so I just ended up winging it with some extra folded bits of copper tape instead. That doesn't work as well as foam but it'll do.
- If you have it, needle noise electronics tweezers would be very helpful, esp for those of us with less dexterous fingers.
I used an extended battery with the extended battery cover and although the fit is a bit tight and there is a tiny opening near the camera, the cover closes and I can live with it for the sheer coolness of this mod.
I used 4 of the stronger magnets that the OP listed. On the desk, it works perfectly. However, if you plan on mounting the Touchstone vertically (e.g., in a car), you'll need more magnets. With only 4 magnets, the phone definitely will not stay on the Touchstone vertically. Simply holding the Touchstone vertically with the phone on it and very lightly shaking the combo will cause the phone to fall off.
Issues that I currently have:
- It seems that the stronger magnets screw up the compass as the compass app goes haywire with the cover on. There were some comments out there regarding magnets that might negate that issue but I haven't had a chance to review those comments.
I haven't gotten the Touchstone to work in my car yet. The same cable/touchstone works at home but not in the car. [SOLVED] Per the recommendation of another post later in this thread, I picked up the Palm Car Charger and the Touchstone works perfectly in the car now.
- Sometimes, the Touchstone doesn't initiate charging. In those cases, I plug the USB directly in the phone, see that it works, then plug the USB back into the Touchstone. I'm not quite sure why this happens.
