tigerhoodz06
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
So I had the same issue with the the android on his back and the caution sign above him, and i tried to rename that file with root explorer and I got a messasge saying "recovery-from-boot.p cannot be renamed because the file system is read-only." Any help would be greatly appreciated.Nope. Pull the battery and turn back on. With root explorer goto /system and rename the file "recovery-from-boot.p", put a 1 in front or .bak. Then with ROM manager reflash CWM and you should be good to go. Boot into CWM.
