7.Skip the initial device setup screen. This can be done by quickly tapping the top-left, top-right, bottom-right, and bottom-left corners of the screen in that order. Or you can just skip through everything without entering your Google account info.
8. Launch TiBu and do Batch > Restore missing apps with data. Now here's the important part.. hit Deselect all. Go through the list and manually select the apps you want to restore with data. You can do it safely for MOST user apps: games, utility apps, etc. But do NOT restore data to any Google apps, and try to avoid it for any apps which actively sync often or create accounts in your phone setup. Can you get away with some of these things sometimes? Maybe.. but just don't take the risk. Restoring any bad data you shouldn't could mean you'll have to re-wipe and start all over again. Once you're done selecting, hit the green checkmark to start the restore.
9. Now run through that last step again... This time after hitting Deselect all, hit App only. Now you can select the apps you are going to restore without data. You can do this for just about anything, including your google apps. Its the same as installing them normally.. TiBu will just do it for you in one quick batch job. Afterwards you can do a Menu > Restore data from XML and restore any the call logs and SMS data we backed up earlier as well.
10. Reboot. Go to Settings > Accounts > Add your Google account and set up your phone again. You can take it from here
