Clancy3434
Apple was evil before the iPhone. I hated that they were locking people into their ecosystem with DRM, so I never used an iPod nor did I ever purchase anything off iTunes.
Good for you. Want a cookie?
Exactly.
Those of us who bought songs from iTunes well before apple launched the iPhone and became evil are pretty much screwed.
Thanks. So iSyncr doesn't do incremental syncs? I only have one playlist which is my entire library. If I buy a new song, I will have to re-sync all my other songs to get that one additional song on?
Ok, back on topic.
Anyone? If I want to add a new song, does it just sync one song or do I have to re-sync all my other songs all over again?
It's been a good 8 months or so since I had my DroidX, but at that time, it only allowed for incremental playlist sync. iSyncr brings up it's own native window/app on your computer.
I could be wrong, and there could have been updates since I last used it, but from what I remember, you couldn't select individual songs. But let's say you put 3 playlists on the phone, then you want to add a 4th, the app will only sync what's new, it doesn't resync everything.
Yeah but if you bought it before they made them all drm free then it will still have drm protection on it...
Sent from my DROID RAZR using Tapatalk
Ok, back on topic.
Hi All,
Let me try and clear up some things about iSyncr.
iSyncr does do incremental syncs over both USB and WiFi. If you are seeing something different, that is certainly a bug (or a misconfiguration) and should be reported. At this time, there are no open issues with incremental syncs.
Laramie8x8, iSyncr does not force close your music player. However, I have seen time and time again that using iSyncr to fill a bad SD card with music can cause all sorts of strange problems on an Android device (at least one customer a day sends an email about something wrong with iSyncr that turns out to be a bad SD card). Almost all of the time, the issue is the SD card (but sometimes a bad USB cable can cause these issues). iSyncr does not inject code into a music player causing it to crash. I promise.
With that said, iSyncr should be getting an update to 2.6.3 today which will add support for the Galaxy Nexus. We got one from Europe, as Verizon/Google are just taking too long.
-Justin
Hi All,
-Justin
So I downloaded iSyncr and got almost all of my music transferred. It said two songs were DRM protected , so I deleted them from iTunes and downloaded new copies. Now when I try to sync it errors out and says an operation is taking longer then usual, restart my machine or if the problem continues e-mail JRT.
Any suggestions? I sent JRT an e-mail but thought I would check on here too.
