Home Button Long Press Not Working
Hey Guys
I used to be able to Long Press the Home Button, and it would show all the apps that I have running, and I would be able to close my recent apps by swiping them.
Now, whenever I Long Press the Home Button, it does nothing.
I have Nova Launcher Prime and WidgetLockerPro (not sure if this app will be the problem or not), and I'm in the settings, and it should work.
I'm at Nova Settings > Gestures and Buttons and in the Button Actions, under Home Button, I have selected Recent Apps. But it's not working. When it comes to Gestures, I just have Pinch IN for Show Previews and Swipe Up for App Drawer. Everything else is set to None.
So I should be able to Long Press the Home Button and go to my Recent Apps (I should be able to do this before having Nova Launcher, regardless!), but for some damn reason, it's not working!!
Please help.
Re: Home Button Long Press Not Working
Quote:
Hey Guys
Please help.
Try clearing data on Nova. Yeah it will reset any widgets/icons, etc but that may be the key to fixing this issue. Besides you can always back up your settings first then clear data and if it doesn't fix the problem, just restore the settings.
I had that issue once and a reboot fixed it.
That didn't work. Any other ideas? :/
- - - Updated - - -
How would I reboot my phone?
Would it be a hard or soft reboot?
Clear defaults on the launcher then switch back to touchwiz. See if it still works there. If not, chances are there's something janky about your home button.
To reboot hold down power button and restart phone.
Sent from my SCH-I605 using Android Central Forums
The reboot did the trick! Thanks!
Just wondering why this would be happening in the first place?!
Glad you got it fixed. There probably isn't a specific reason it happened. Sometimes electronics go wonky.
