Jazzur55
You need to go to Settings>scroll all the way down until you get the "accounts" section (you will see all the accounts like facebook, twitter, etc)>click on google and then click on your gmail addres, you will see all the syncing options and at the very bottom you will see 2 buttons: sync now and remove account (you need to click on remove account =P)
on that same screen you can see if the calendar is checked just to double check.
-cheers
-cheers
